Fuel vaccume check
marinemike43
I have a 1989 Evinrude 88hp SPL,bought a vaccume gauge.
Does anyone know what the specs should be for checking for leaks in the fuel lines?
Thanks Mike
5150abf
Re: Fuel vaccume check
The easiest way I have found to find fuel leaks is to pump up the line and check all your connections for leaks..
A vacuum leak may show up but you won't know where it is.
Being 02 years old you shoul dprobably replace all your fuel line anyways from the tank to the carbs, use small hose clamps on the line and zip ties on the carbs then you know it is right.
