ugbandtulsa
Thread starter- Joined
- Jul 2, 2006
- 34
Wow, i didn't know the fuel/water unit on a merc could just "fail", and I'm not talking about the filter, I'm talking about the actual unit!
I haven't had time to dissect it, but my darn formula 272 would absolutely NOT run over 2000 rpm, and was losing fuel spray around that rpm into the carb. Thinking it was a fuel problem, naturally, i replaced the pump, checked the voltage, then the filter inside the quadrabog, STILL had the same problem!
Only after i ran a direct line from the pump to the carb did it "voila" the problem. Any idea why a unit like this would fail? It's just a pass-through design, with no moving parts, right?
Anyway, if you ever get this symptom, you'll know what it is!
