crazy charlie
- Joined
- May 22, 2003
- 5,749
Some of you have probably seen my posts on my 1984 115rude that lost its idle one day.I was about to rebuild the carbs after posting the problem.Just before I pulled the boat I did a compression check and got bad news,3 cyl at 115 and 1 at 20-30.I quickly assumed the no idle was because of this.Since most mechanics did not even want to look at it and prepared me for a 2000 bill if I wanted it rebuilt,one mechanic suggested to raise the idle until it keeps running and use it until it craps out.In a last effort I unloaded a can of seafoam into that cylinder,let it sit,and started it to see if any improvement.None that i could see.I still have to pull the head to look inside but I unloaded 1/2 a can of pt buster into the same cyl and it still seemed the same,I took it for a ride and it has full power.I am baffled because it had full power when i was about to rebuild the carbs and discovered the low comp. in 1 cyl.Is it possible to run at what feels like full power with 1 low cyl?????????????Sorry for being lengthy Charlie
