Starboardlean
- Joined
- Feb 15, 2016
- 73
1978 85 HP Evinrude. Cleaned and Rebuilt carbs. New fuel pump, fuel lines with filter, 4 spark plugs,4 coils,1 power pack, water pump, About 105psi each cylinder. Strong spark. 50:1 pure gas/oil. Last time out( last weekend) it had a "hiccup"(bog down) at close to WOT. Ran fine when backed of a little. Kinda played around to repeat "hiccup". Sure enough more than a few seconds near WOT and it happened again. Tried to "jump" it on plane versus the usual easing into it. Hiccup and it couldn't plane. Repeat and this time ease it on plane no trouble. Momma then took control and I worked the bulb, hiccup still! Cruise at 3/4throttle all day fine....New Ql77jc4 installed Friday..Today we go to the lake. Starts easy enough....whatever happened near WOT has now happened to any attempt to exceed the no wake speed. Push the throttle forward, just a bog, and a occasional blip of power that quickly dissipates. Stalls. Restarts fine. Occasional bog now just one constant bog. But she idled back to dock fine. Get home removed air intake cover and have small puddle,maybe a thimble full of fuel in the cover,fuel obviously oozing out of top carb. Normal? Ideas or pointers??
