function of this part???
txNeal
This is my second post to this site. My first was about the starter pull cord that would not rewind and, thanks to replies I received, I have it fixed and working perfectly now! I now have another problem and am hoping for some similar good advice. The motor is a 1973 Evinrude 25hp model 25302A.
The part in question is the linkage between the throttle and the choke. I have looked at the diagram that I found though the sticky at the top of this forum, entitled ""top secret file"....'manual and diagrams'. On the diagram, there is a connecting rod between the choke and throttle that is labeled #54 LINK, throttle lever to choke bellcrank. While disassembling this linkage last night, a small plastic retainer was lost and then subsequently found today (although it was found broken in half!). It attaches #54 directly to the plate on #12, the throttle shaft. However, according to the diagram, this little plastic retainer does not even exist....so I'm wondering if someone may have placed it there as a substitute for another part. In the diagram, it appears that there is another part, #73/74, Arm Assy, shaft and screw/arm to shaft that I do not have on this motor. This is where I am getting quite confused!!!
First of all, I can't quite make sense of the purpose of this linkage. I don't have much knowledge of these motors so please bear with me as I ask for an explanation. As far as I can tell, this linkage seems to serve the purpose of closing the butterfly valve (choke) when the throttle is engaged....is this correct or am I way off on this? As I position everything into place (with the broken plastic retainer) and then move the parts, it seems that all it does is close this valve when the throttle is opened.
If anyone is familiar with this linkage, it would be really helpful to me if you could explain what the function of it is. Do I need to find parts 73 and 74 to get it to work properly or should I be looking for another plastic retainer like the one that broke off of it? I am at a total loss for what to do next, so any help with this would be a step closer to getting it all figured out. Thanks!
Vic.S
Re: function of this part???
The purpose of the link I am sure will be to open the throttle a little when the choke is applied, not the other way round.
I'd say that arm #73 should be fastened to the plate on the end of shaft #12 with screw#74 and that the link #54 connects between that and where shown on #14.
Cannot explain why no clip is shown or why you do not have #73 and #74
Sorry not much help!
If all else fails perhaps you can open the throttle manually a touch when using the choke.
5150abf
That is just a genaric diagram and certainly doesn't cover every engine exactly, you will need an OMC manual to have exact diagram of your particular engine, you can get one here at iboats.
HybridMX6
Or you can go to shop.evinrude.com and pull up your engine and look to see how they have it. It should show your exact motor in parts groups, I.E. carburetor, gearcase, crankcase, etc.
txNeal
Thanks for your replies. I had actually wondered if the sole function of that part was to crack open the throttle a tiny bit when the choke is applied. Now that someone else has verbalized that possibility, it seems to make perfect sense! As far as the diagrams go, I believe the one in the link I looked at is exactly the same as the one at evinrude. I have ordered a factory service manual and am expecting to arrive in a day or two, so I'll see it shows anything different, but I am beginning to believe that I need parts 73/74 to make the choke function properly. Thanks for taking the time to reply.
F_R
That is the correct function of the link--to kick the throttle butterfly open a bit when the choke is pulled. Remember back when cars had carburetors and we held the accelerator pedal down a bit when starting?
I can visualize that little clip in my mind and know I've seen it, but I can't find it on the diagram either. The one I'm thinking of is held on be a screw and the rod slides back and forth through the "fingers" on the clip. OR, I'm thinking of another model.
txNeal
I'm glad to finally understand the function of this linkage and now I just need to figure out how to attach #54 to the plate on #12. As I stated before, I do not have anything that resembles #73/74. The rod, #54, was connected directly to the plate on #12, but the plastic retainer is broken now and will not work anymore. If I were to find a place to purchase 73/74, is there a way to attach the rod to it? This is all still unclear to me. I'm not understanding why I had a plastic retainer rather than 73/74 and am wondering if I just need to find these parts in order to put this thing back together. Does anyone have a recommendation for a parts supplier with a phone number so I could talk to someone who is familiar with this? Thanks again!
F_R
OK, I found a diagram as I remember the part. Look at the 1968 model 18802A on the BRP website.
Item 41, part number 204488 Support, control rod, $7.50
Item 39, screw
Item 40, washer.
http://shop2.evinrude.com/ext/index.aspx?s1=fc502fad3f51ed0e319aa8bdd7efb79a
EDIT: OK, so after looking at it some more, I see that the '68 and '73 have different throttle shafts and connecting links. So, I guess the one that I remember probably won't work. I tried...
