Furrylittleotter
- Joined
- Oct 16, 2014
- 167
Im not sure what y'all are talking about. the depth of my rudder and prop is equal or less than a typical Starcraft outboard. Obviously it will not "Give" like a hinged drive will but the total distance form the hull is only 14 inches.
If this setup had "added a foot" to the original depth the original depth would've had to have been 2 inches. It wasn't.The original skeg depth was probably 16-18 inches if I had to guess.
I think the photos must be deceiving.
The bad news today is the plate that the drive had with it kept the drive from going low enough.:
I took it apart and the plate can NOT be flipped and I am not going to weaken the plate by cutting it, so i ordered a new 1/2" plate 12" by 24" aluminum plate to make a new mount out of.
Reason being is the Drive contains the THRUST BEARING for the whole propellor shaft, the thrust is not transferred to the strut on this design so it has to go somewhere and that plate transfers the load to the Stringers, which, in turn transfer the load to the frames and transom.
So with the plate removed, here is the drive in place:
It only goes about 4 inches over the original floor. I had planned to build the floor up 2 inches, but may change plans later, possibly build that area p 4 inches for a footrest. Not sure yet.
The good news is I wanted to be lazy and not take the drive apart. Im glad I did because it doesn't have a drain plug, and I never could've gotten the fouled gear oil out without taking it apart. I will add a drain plug and possibly replace a questionable bearing.
I measured the seat height.. It looks like my 24 inch pedestals and 2 inch floor will give me the perfect height for driving. We shall see for sure when they get here.
I did a bunch of other measuring and it looks like the layout is going to be AWESOME! Lots of room at the stern (34 inches?) , 22 inches to walk past the motor box and the motor will be pretty low so I can put a cooler or seat on it. again, have to wait and see.
Neil
Neil
