Re: further help ,starter not turning
i'm not getting any connection on any terminal I test. (yes, my lite is working)
Ayuh,....
The Ultimate Test of a solenoid is quite Simple....
Take a set of Jumper Cables,.....
Take 1 of the Positive cable clamps,+ attach it to 1 of the BIG lugs on the solenoid,.....
Then take the other Positive cable clamp,+ attach it to the other BIG lug on the solenoid.....
The solenoid has now been eliminated from the circuit....
Now,.... Try to start the motor,...
Does it Start,..?? If so, replace the solenoid....
If Not,... Move on to your next link in the circuit......
Btw,.......
Why have you started a 2nd thread about the Exact Same Problem,..??..??
While your original thread is still playing on page 1,..????
Duplicate Threads are frowned upon around here,...
It's confusing enough for the regular posters to keep track of Helping you guys out,...
Without running 2 threads about the Exact Same Problem on the Exact Same boat......
If you have more questions,+ need more answers,..
You should be posting on the 1st thread to bring it to the top,+ keeping All the pertinent Info together.....
Good Luck.....
