Fuse panel
CapJB
I have a 2000 fourwinns sundowner 215 and I lost power to my instrument panel and was wondering if there was more than one fuse panel other than the one under the dash because all those fuses are good.
Will the motor still run with gauges off?
There can be a inline fuse on the Red/purple wire feeding the key switch
newest4u
alldodge - the inline fuse on the Red/purple wire, where does that wire connect to in the fuse panel? Do you just plug it in any + fuse box?
There "may be" an inline fuse, and if its there it doesn't connect to the fuse panel. Find the red/purple wire at the key switch and follow it back to the fuse (if its there) or to the fuse panel if its not a inline type
