Fuse size
Fishaddicted
I have a 1998 40 hp force elpt i bought it had a 10 amp fuse on motor is this the right size fuse for this motor previous owner says it blows sometime i know theres a short somewhere but i just fix one thing at a time due to busy work scheduel and people have been very helpful here and thanks for all your help
fhhuber
Intermittent shorts eventually become continuous shorts and that can lead to a fire....
Find it and fix it. A fire in a boat will ruin your day.
jhebert
Ensign
It is typical that an outboard engine will have a fused circuit with a 10-Ampere fuse that provides power to its remote controls at the helm.
roscoe
Hello addict, your motor came with a 20 amp fuse.
Guessing the 10 amp blows when the power tilt was being used.
The proper (20 amp ) fuse should remedy that.
Here is a partial parts list for your motor, showing part #14, 20 amp fuse.
http://www.mercruiserparts.com/bam/s...y/30150/2532/2
119-45907 PLUG, Yellow, Crankshaft/Flywheel ACT $5.10$4.981
211-42979 NUT, (M16) ACT $3.20$3.131
312-33001 WASHER, (.641 x 1.250 x .190)68229SS/ACT
$5.10$4.981
4261-9008A52 FLYWHEEL ASSEMBLY9008A34SS/NLA
$395.40$0.001
537-825149A1 --DECAL KIT, Shift to Neutral NLA
$195.17$175.951
610-19926100 SCREW, (#10-24 x 1.00) ACT $3.40$3.326
7398-832075A21IGNITION STATOR KIT832075A4SS/ACT
$287.42$259.111
8855744A2 TRIGGER ASSEMBLY854509SS/ACT
$141.66$127.721
956762 TIE STRAP, (4.00 Inches) ACT $0.30$0.30AR
1054-816311T TIE STRAP, (8.00 Inches)816311SS/ACT
$0.44$0.43AR
1184-828296A1 HARNESS ASSEMBLY, Wiring ACT
$152.00$137.031
1213541 --PLUG, Male ACT $2.20$2.151
13828054 --COVER, Fuse ACT $4.20$4.101
1488-812619 --FUSE, Yellow - 20 Ampere
