FW 180 V/P outdrive...will not go in gear
dak1611
Started boat for the season last night....all looked good until i tried to put it in gear. I could not get the shifter to engage. With the neutral button depressed I can move the shifter, but not when trying to go forward or in reverse. How do you get the side panels off to look at the shifter?
Don S
Re: FW 180 V/P outdrive...will not go in gear
What outdrive do you have? What engine? FW 180 is not an outdrive.
Probably a bad shift cable on whatever it is you have.
