G3 Bay 17 transducer placement
Stump Sitter
Looking for guidance on positioning a down imaging/side imaging transducer on this boat. The lower transom has a couple of features I don't understand.
1. the two small trim tab like extensions. 2. the slight concave extensions at bottom/transom junction.
These features are on both port and starboard sides.
Any guidance would be appreciated. Thanks in advance.
dingbat
I suspect it’s a transducer mount so you don’t have to drill the hull.
Mount lays flat instead of you typical 90 degree when mounted on the transom
alldodge
Instead or the bracket being up and 90*, it's layed flat and secured on the plate
Stump Sitter
Ding, I went out and checked and you might be on to something there. Unfortunately for me, my Garmin transducer mount will not lay flat. Maybe a little DIY modification ?
Thanks again !!
Stump Sitter
Looks like adding a piece of aluminum angle to the tab might be the ticket. Thanks to all for the suggestions !!20241221_105816.jpg
