gale 1960 5hp shift rod
foretopman
I am trying to find a way to remove the lower case, the shift rod is preventing this. I need to rplace shaft seals after checking pump impellar (shaft seal parts at the motor end fell out during the check)
Help!
steelespike
Re: gale 1960 5hp shift rod
You need to remove the power head to disconnect the shift rod.Pretty straight forward.
steelespike
A great video.Any fool could do it,especially me.
Just a note.I believe the 55 model Gale 5 you don't have top pull the power head.It has a 2 piece shift rod.
64osby
Foretopman - I just did this on my Gale 5hp - the only tricky part is on reassembly you have to make sure the tube that fits into the waterpump gets in the waterpump. Mine would not line up. I was able to use a long thin screwdriver and a flashlight - looking through the exhaust outlet I was able to get it lined up and it slipped in. Its kinda a three handed job - at least for me it was.
Good luck
What a nice video, makes it look too easy.
