I have a lot of extra 6hp parts left over from the restore/creation of my twin 6hp's.
3 of the engine I received had blown/seized/overheated power heads.
I had one 1963 sea king 5hp. I needed a shift handle so I borrowed it from that engine. Now I have myself a really nice 5hp powerhead, putting 70ish psi in each cylinder.
The gale had the pull start on top of the flywheel, unlike the 6hp's that had the starter looking pull start. I want to use one of my evinrude hoods on it, as the seakind hood is an ugly duckling joke.
So, the plan is to bolt the 6hp "intake manifold to plate" plate onto the 5hp thus, allowing the brackets for the starter. Then remove the gale ignition system, and replace it with the 6hp. to allow for the 6hp flywheel.
All that I believe SHOULD work. However, the 5hp's carb has 2 adjustment knobs, where the 6hp's only have one, so, carb swap too.
Will all of this work? opinions, thoughts?
Pics:
Edit; fuel pump.... 6hp too?
You may ask, what about the shift handle?! I'll use a broken on for my Frankenstein outboard. Ill probably put 2 large bolts on hood pan just to keep things interesting.
Pics:
