Gale Sovereign 40HP won't run
Riknar
Re: Gale Sovereign 40HP won't run
F_R
you have some great advice EVERY time.
I am shifting...and the throttle is positioned just as you seen it in the pic.
I am guessing that is wrong?
Like I said...this is my FIRST outboard. I grew up with boats, but someone else always did the work.
I am learning fast though...hahahaaha
I am actually thankful for the problems, so I can learn.
I will adjust the throttle as you specified...and see where the shifting is afterwards.
Some times it shifts easily, other times...it is like it is stuck and has to be forced. Could be the shaft...who knows.
Will keep you posted. And again...thanks
Dave
F_R
Throttle has to be at "slow" to shift. Also, if not running, you probably will have to give the propeller a twirl so the gears can "fit".
The shift shaft problem won't come and go. If it's frozen it's frozen till you fix it. Must be something else.
Riknar
See...I was thinking that!
I will wait till I get it going before I mess witht he shifter.
The Throttle adjustment...
What position should I have the throttle in before adjusting?
Slow? Start? Full?
Riknar
Figured it out...
Did the throttle adjustment...now it makes more sense.
Set the throttle to slow...gear shift works perfectly.
geez, you know your stuff. hahaahha
Supposed to pick u[ the coils and all that Friday, but don't think I can wait. Hoping to plunk this in the water this weekend.
Riknar
HEY!!!
I got me a running motor!!
The coils did the trick!
Now...Why is it that it won't stay running unless I choke it...the speed dwindles, I hit the choke and it kicks up again...
any ideas?
Could it be the needle valves? I have the two...upper and lower...
F_R
Certainly, adjust the needles. Lower at high speed and upper at idle speed.
Riknar
I had removed the needle valves when I cleaned up the carb...
is there a specific way to re-install them?
I might have them buggered up...
not sure.
samo_ott
Definitely. Search the forum for the blurb from Joe Reeves about initial carb setup. You need to do it if ever removing your needle valves.
And make sure you did not cram any packing material back in when reinstalling them.
Riknar
Awesome...
anyone have a link to this thread by Jim Reeves?
moterboat
:rolleyes:your problems kinda rare, the gales and elgins usally will run fine and get you to the end of your destination,then break down. you have to paddle back.. thats all I remember about them in the 60's.
