FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have an early 80s Sears Gamefisher 9.9hp that runs well but I have to constantly pump the primer bulb on the gas tank to keep it running. Any suggestions?<br /><br />Thanks, John
Re: Gamefisher 9.9hp - have to pump gas bulb in order to keep it running
Make sure the vent on the gas tank is working right or replace the hose and bulb before you tinker with the motor.If thats not it then check the fuel filter.Stick with the simple stuff first.Charlie
Work from the tank to the carb checking for air leaks, pinched lines, etc. Connections are the most common cause of air leaks. My experience is that fuel pumps are seldom the problem unless they've gotten gummed up from sitting too long and then just running them for a while will frequently dissolve the gummy stuff.
