Re: gamefisher electronics
The problem is that on those Tecumseh engines, the module isn't just a module. It has it's own little coil in it that's used to pickup a timing signal from the flywheel magnets. That means that it's not going to work to hang some other CDI unit on there.
The further problem is that, like most outboards, timing advance is done by moving the timing plate, shifting the pickups in relation to the flywheel position.
No doubt, a system could be cooked up using something like an automotive optical system, external to the flywheel, but that's a big job for an amateur engineer. Those systems also require a conversion to a battery ignition, as well. It's just not worth the hassle.
I was considering fooling around with this whole thing, since I had a 9.9 Eska with that ignition system. I thought better of it and sold the silly thing for $40. It just wasn't worth the trouble it would take trying to jury rig something.
There's a guy on the web who has worked out a repair for the module on one of the Tecumseh garden tractor engines. He dug out the potting material and replaced the burnt-out diode, but it's not the same ignition system, exactly. I think he also figured out a automotive parts replacement method, with the problem that it had to be battery powered, as I mentioned above. Not a big deal on a garden tractor, which already has a battery, but not so ideal for an outboard. Also, the garden tractor doesn't have the same advance mechanism as the outboard.
Still, Googling Tecumseh Solid State Ignition will find that page.
I have no doubt, whatever, that it's possible to engineer a system that will work on those Tecumseh outboards. But, with the value of even the 9.9 and 15 hp twins being about $250 when they're running perfectly, I guess it just doesn't have much appeal to people who are capable of figuring it out.
I could do it, but I'd rather go fishing in my old age. When you can buy a nice Johnnyrude 6hp for $300 or so, what's the point of spending a bunch of money on an air-cooled 7.5 hp that won't perform as well?
My reason for posting on these topics is that I've been in the same position with a 30+ year old Eska, and want to give fair warning about what to expect.
If you know of an actual working solution for the situation, then please post it here. I'm sure there will be lots of people interested.
