gap on certain spark plugs??? HELP NEEDED
14bassguy
I need to know the gap on champion j6c and NGK B6S. I need to know in order to fix a problem with my motor. thanks in advance
alangf
Re: gap on certain spark plugs??? HELP NEEDED
Most applications using a J6J gapped at .035". I don't know about the NGK plug.
steelespike
Plug setting depends on the application.
alangf
You are absolutely right but most outboards with points used .020 on the points and .035 on the plugs. There may be minor variations but I've never seen one that would not run (and run well) at .035.
