what would be classic symptoms of incorrect point gap......either too close, or too wide????
nwcove Admiral Joined May 16, 2011 Messages 6,293 Sep 20, 2011 #1 what would be classic symptoms of incorrect point gap......either too close, or too wide????
cr2k Captain Joined Mar 19, 2009 Messages 3,730 Sep 20, 2011 #2 Re: gapping points To close may run better at higher RPM and too wide would run worse at higher RPM. Either case may sputter, backfire or not start. It is always important to use the lube provide with the kit so the rubbing blocks don't wear.
nwcove Admiral Joined May 16, 2011 Messages 6,293 Sep 20, 2011 #3 Re: gapping points thanks cr, was just curious about what a few thousands of an inch really makes , one way or the other. (have been playing with a single cyl motor point gap)
