the_smoo
Thread starter- Joined
- Jul 11, 2010
- 41
Hi all,
Have had my boat now for about 5 weeks. Been out a few times and noticed a small amount of water in the bilge after each day. Traced the leak to the garboard drain.
Removed the drain and all the "factory" sealer and found this. Wasnt sealed well at all and there are cracks around where the bottom screw is.
Inside the two higher screws the wood is dry as a bone, the bottom screw wood seems damp. Plan is to dry it out before attempting repair.
Not sure how to go about it. Should I seal inside the sides of the hole and the cracks on the outside with epoxy then use 3m 4200 sealant and reinstall the garboard drain. (with some sealant in the screw holes as well)?
Dan
Dan
