garmin 340c
dan t.
I am thinking about buying a garmin 340c depth sounder, anyone out there have one? what are your comments? Icurrently use an Eagle Optima but it just doesnt have the power for 250 ft plus depths that we fish in. some thing that works at speed would be nice also
dan t.
Re: garmin 340c
come on people, someone must have one of these,sure would like some feed back.thanks Dan
sailsmanship
Re: garmin 340c
I have one that I bought earlier this year, and have had a tough time getting good reads from it. I have adjusted transducer multiple times with no luck. Transducer is in the same spot as the previous b/w Garmin unit that worked well. I'm tired of trying and probably going to put it on E-bay and try something else. I do like Garmin as I have had quiet a few GPS and Sounder units over the years, but this one is frustrating me to no end.
dingbat
Re: garmin 340c
What is it doing? What transducer are you using?
sailsmanship
Re: garmin 340c
Using the transducer that came with it. When underway it always loses bottom and flashes 00 depth. Will hold depth at anchor or drift then lose it. Fish markings are poor in situations on others that always have been clear. It just doesn't seem to perform well. Bottom contour in areas that I know don't always seem to ring true. I boat usually in Western Lake Erie where average water depth is only 30 ft.
dingbat
Re: garmin 340c
You're loosing signal somehow. First off, make sure your running the unit in 200 kHZ mode. Then try running it in manaul mode and turn up the gain until you get a second bottom return. See if it holds bottom then.
If not, lower the transducer further down in the water. If that don't work you have a problem with the transducer.
dan t.
Re: garmin 340c
thanks guys, I may hold off on this and see if sailsmanship can resolve this problem. anyone else have one of these? his seems to be acting just like my eagle does but it is ok in up to 100 ft.
sailsmanship
Re: garmin 340c
Thanks, I'll have to try doing that, problem is I'll have to wait till Spring. Its' tucked away for the winter..
