Garmin Striker shutting down
KJM
My Garmin Striker has started shutting down every time I start my boat. Before this it would warn low voltage momentarily but not shut down. I'm assuming this happens because the voltage goes too low now. The battery starts the motor fine. Does this mean my battery is getting too old? It's about 4 years old, deep cycle. How could I test the battery?
dingbat
Yes, that’s your problem.
Take it somewhere to be load tested
  • Like
Reactions: KJM
airshot
Most boaters use INE battery for starting purpose only, then another deep cycle as a house battery to run everything else. This way you always have starting power. Unless the motor is fairly small, the heavy draw of starting can shorten the life of a deep cycle battery.
mike_i
Measure the voltage at the unit or at the fuse panel while starting the motor. I agree with the above, your battery is running low.
airshot
Most boaters use onebattery for starting purpose only, then another deep cycle as a house battery to run everything else. This way you always have starting power. Unless the motor is fairly small, the heavy draw of starting can shorten the life of a deep cycle battery.
