gas cap
JABBO
I have the original gas tank that came with this boat(plastic). The cap does not look like it is vented(it has a hole underneath but it does not come out the top nor does it have a screw). Could this cause a problem or does it need to be vented?
tashasdaddy
Re: gas cap
not knowing what tank you have i could not answer, some caps are vented that way. some you just have to loosen 1/2 turn.
JABBO
Re: gas cap
Built in tank? If so, it should have a vent hose and a fuel hose. Some fixtures accomodate both hoses, some boats have two separate fixtures.
More here: http://www.iboats.com/basics/fuel_system_tips.html
This is not a built in tank...just sits in the back by motor. Just wandering because I have something going on with this motor. After i leave it sitting a few days it is really hard to crank. I don't know whether it is losing prime or not getting enough gas or sucking air. When I start to crank it I squezze the bubble about 2 or 3 times before it is tight,then lift the fast idle lever. Then turn on and push choke in for 5 or 6 sec. then try to crank.Sometimes it takes me ten minutes or so of trying then letting the starter cool and then trying again before it will crank. Alot of trouble!!! This does have the oil injection also. Any ideas?
ezeke
Re: gas cap
When you push the key in, it allows the pressurized fuel from the bulb that you squeezed to bypass the carburetors and spray into the intake manifold. It does not get the fuel to the firing chamber, only the action of the pistons can do that.
Therefore the procedure in most OMC manuals is to push the key in while cranking, not before.
JABBO
Re: gas cap
Well I've tried that too. I'm going to start with getting my fathers tank and line and see if that makes any difference. If not then I will start on the filter and carbs I guess.
tashasdaddy
Re: gas cap
what motor? hp,year? what maintanance has been done, how long ago? last time carbs were cleaned, and rebuilt with a kit? last time you checked compression and spark? di it just start doing this? how long have you owned the motor?
JABBO
Re: gas cap
1996 Johnson 35hp. 3 cyl.--have not done any main.---got new plugs to put in today---started doing this last year---have owned the boat/motor since last spring---before then it sat up for appr. 2 yrs.---this boat/motor was repoad. and we got a really,really,REALLY good deal on it---16ft. Grumman boat---seems to run pretty good top end just hard to start most of the time.
tashasdaddy
Re: gas cap
if it sat for 2 years, so now 3years. you need to clean and rebuild the carbs, including the low and high speed jets. replace the impeller. the carbs are clogged up. the impeller is dried out, and will disintergrate. seeing it was a repo i would want the compression readings before spending any more money. post them. here's some more good info:
http://forums.iboats.com/showthread.php?t=158086
JABBO
Re: gas cap
Ok...Very good info, but just how much of that do I need to do for the problem I have. I have about spent myself right out of my house and in the doghouse so I am going to have to try to pick which one of these(or two) that will do me the most good and do it. Thanks you for all the help. I know you are going to say with my problem to go ahead and rebuild the carbs. right?
tashasdaddy
Re: gas cap
you need to rebuild the carbs, for it to run, properly, and replace the impeller, to keep from burning up the power head. these 2 are a must before you put it on the water.,
JABBO
Re: gas cap
Ok...will get that done. Thanks again!
