5150abf
Thread starter- Joined
- Aug 12, 2007
- 5,808
Working on a freinds motor, '76 50 and it will only run on one cylinder, has spark, compression okay.
When you try to start it gas comes out the front of the carbs and when it finally does run there is a fine mist of gas coming out of them and you can feel engine pulses, this is bad reeds yes.
History, last year he calls me and said the air cleaner thing "fell off" the front of the engine, I found 2 bolts in the air box and the other 4 were stuck in the reeds, the engine ran okay for the last year, now not so much.
I haven't actually torn the carbs off yet to look at the reed cage, should I just tell him to get new ones?
