jackganssle
- Joined
- May 8, 2012
- 1
Folks,
I bought a new 4 cycle Tohatsu 9.9 last year. From the very beginning I found that after about 8 hours the fuel that is in the gas line between the tank and the motor turns bright yellow, and the engine can't burn it. The gas in the tank is OK, so if I drain the hose, all is well. Except that getting rid of that bad gas is tough when off cruising for a few weeks.
I thought maybe the hose needed to shed some stuff as it was new. But after a year the same problem persists. And Stabil in the gas tank doesn't cure it. I've tried gas from three different sources.
Any ideas? It's very puzzling.
