man-of-war
Thread starter- Joined
- Apr 23, 2004
- 175
Hello Again,<br />I've just about run out of options on what's causing the gas to enter the crankcase. I replaced the carb, replaced the fuel filter/water separater, replaced the fuel pump, custom made fuel lines, new MSD 8.5MM plug wires, new distributor cover, new 14" air filter, new spark/ damp brown/black colour. The mechanic said that he ported the ebelbrock preformer 2 intake manifold because the ports on the head are round? So he made the ports on the ebelbrock round as well. I removed the carb and noticed that he also removed/shaved the divider in the ebelbrock intake. This divider separates the fuel/air from left to right. Could any of these be the problem of causing gas to enter the crankcase? Any other suggestions are welcome. The engine is a 1975 454 Chevy Big Block 7.4L V8. How can I check to tell if the intake manfold is cracked? I have a vaccuum gauge hooked up to the intake manifold. Is there anything I should be looking for on the gauge? Could this be a factor? Thank you
