Gas line on a 25 hp evinrude..
zackduncan40
Would it be okay for me to put an in line fuel filter after my siphon bulb? Or would that restrict my gas flow too much?
fhhuber
Just be sure it fits the hose and use good clamps so it doesn't leak.
Your 25 won't have a problem with just about any filter that is going to work without an adapter to fit the hose.
gm280
Most any place before the actual carb will work. BUT, if you put the fuel filter before the squeeze bulb, then you eliminate debris from even getting into the squeeze bulb as well. And that may make it last longer. :noidea:
