gas octane
chuck-p
I have a 1974 lark 50, my owner's manual says to run a minimum octane rating of 94 but after reading many posts on iboats everyone seems to recomend 87.<br />Should I continue to run premium or is 87 ok.
JB
Re: gas octane
That was 31 years ago, Gonfishin.<br /><br />87 is the stuff to use in 2005.<br /><br />Good luck. :)
oldboat1
Re: gas octane
Has it really been 31 years? I think it matters whether the gas is fresh, but octane isn't so critical. Having said that, I just bought a couple of gallons of premium for use in testing out a motor I want to get running -- at $3.79/gal. Regular was 30 cents cheaper, but at that price 30 cents just didn't look like much more.
chuck-p
Re: gas octane
thanks for the quick replie guys i am going to start using 87 and save a few bucks.
Pony
Re: gas octane
i thought the combustion temps on the higher octanes was too high for outboards....in that they leave higher amounts of residual carbon etc. which i believe is why most people here recoment the 87octane. om sure someone can back me up on that.
djzyla1980
Re: gas octane
87 is what a mechanic at one of the shops here told me... for the same reasons pony... <br /><br />However.... here it costs more to run the 87 then the 93 or 94.... by about 25 cents<br /><br />So keep saving money so I can spend more :)
itstippy
Re: gas octane
That's the first I've heard of OMC recommending anything other than 87 Octane. The owner's manual says "minimim" of 94!? What's the scoop on that, you experienced ones? Part of the unleaded fuel panic of the early 1970's?<br /><br />Dave, you get 94 octane for 25 cents cheaper than 87 octane? Around here they call 94 octane "premium" and charge an extra 40 cents per gallon. It's all my old Honda car will burn, so I bite the bullet and pay the price. "Old Blue" knocks & pings & diesels with "regular" gas (87 octane). At 233,000 miles I just buy the premium fuel - I'm not about to mess with the motor! But I run fresh 87 octane in all my outboards.
chuck-p
Re: gas octane
Here is a quote from my owners manual<br /> "RECOMMENED GASOLINE <br /> Use a Regular leaded gasoline or a Premium leaded gasoline that has a minimum octane rating of 94 (Research Number).<br /> NOTE: If recommended gasoline is not available when operating in any other country than the United States, Canada, or Australia, see your DEALER."<br />Evinrude 1974 ownener's manual<br />50HP<br />Lark Models 50472<br /> 50473<br />Sizzler Models 50442<br /> 50443
chuck-p
Re: gas octane
Where the 1974 50hp's a higher commpresion motor, or has gas changed that much in the last 31 years.
djzyla1980
Re: gas octane
Yeah... it pisses me off everytime I see it. the 94 has ethenol... so I believe it's there way of getting us to buy "clean" burning fuel. I don't ask I just buy. maybe were just half a$$ backwards here but it's that way at all the stations I've been to. Go about 100 miles south and it's the way it should be.... Who knows<br /><br />My manual actually states 94 octane for my motor. But that was in 70's so I'll stick to what the pro's say and pay the extra for cheap gas....lol
Paul Moir
Re: gas octane
Research number (AKA RON) is a different rating system than used in the US/Canada, where we use Pump Octane numbers ((MON (motor octane number) + RON) / 2). 94 would generally be about equal to 89.
chuck-p
Re: gas octane
Thanks Paul that clears up my questions about octane and wich gas to run.
Paul Moir
Re: gas octane
I would stick with 87 myself, as JB said. After all, how many posts do you see here from people with predetenation damage caused by too low an octane fuel? Verses the numbers you see with coked up rings?<br />Up here, I run into other problems when using high-octane fuels. Rubber parts dissolving, platic parts cracking, etc.
