gas oil ratio for 15hp sears Ted Williams Outboard???
Redbone Bunker
My Grandfather left me an older Sears Ted Williams twin cylinder 15hp outboard motor. The Chassis# 217/28631-1 The Serial# 6D112387 Does anyone know the gas/oil ratio for the engine and the proper oil to use. Last time I used a good synthetic that I use for chainsaws and leafblowers , but it didn't seem to have the top end power that I thought it should. I'm also going to check/change the lower unit oil seeing that the engine sat for almost 15yrs. Any info would be a huge help!
windy5849
Re: gas oil ratio for 15hp sears Ted Williams Outboard???
I couldn't find the model number you posted.If it is 217.586311,then here is the information you need.
http://home.earthlink.net/~brixent/Model217585870-586351.htm
It is a 1976,15hp and the mix ratio is 50:1.Don't use the air cooled oil for chainsaws and leaf blowers.Only use TCW3 oil which is formulated for water cooled motors.Hope this helps.
narwhals
i tried looking up your model on sears parts lookup and it came back unidentified. most powerheads for sears were built by eska,which is a tecumseh unit, the fuel ratio is 50-1 but use a marine grade 2 stroke oil as they are designed for the the waterways for less pollution. you could use regular oil for lawn and garden in a pinch but i recommend using a marine grade synthetic for optimum performance. lower end oil is 90w gear oil and it should hold @ 6 ounces. to remove and replace the oil remove the 2 screws in the lower unit aloow oil to drain into a pan, you can blow compressed air into the top hole to try to get remaining fluid out.they make kits for doing the lower end oil replacement. i have used an old piece of fuel line hooked up to end of gear lube and screw it into the lower hole and squeeze until the fluid comes out the top hole.replace both screws and your on your way, if you need additional help refer back to your post and i'm sure someone would be happy to help you. welcome to iboats and good luck on your project.
Redbone Bunker
To both windy5849 and narwhals: Thank you both very much for your time and help. This info. will be a tremendous help. Now I can get my grandpas old rig out on the lake again. I just hope I have his good luck with the pike and bass. Thanks Again... Redbone Bunker
axeman1988
to redbone bunker, i have the same out board model #. yes it is 1976 and it is available on searspartsdirect.com i ordered a water impeller for it and had it in 4 days no problems they also have blown up diagrams of the outboard itself. so you can make a good work guide for you outboard. any more questions just reply back or personal message me
