I have a boat I put some time and money into and its now safe and ready to go (almost). The previous owner had let the boat sit outside with the gas cap off. Knowing this I siphoned the water out of the tank and added 10 gallons of gas. I added a new water separator and inline filter in front of it.
Took the boat out and ran it, and the gas pickup tube in the tank immediately got clogged. I was prepared for this and I kicked it in. I took the consol off and got to the 42 gallon tank underneath. I took the pickup tube out and cleaned it (amall screen clogged with rust type stuff). I decide to take the gas inlet tube off. I found a metal spike (rusted and corroded), rocks, and some other stuff down the gas inlet - little kids did this I?m sure.
I know a little of this debris probably got washed into the tank when I filled it with 10 gallons for the test (rust mostly I?m guessing). Am I ok with just using a filter to keep the junk out of the motor? The tank is practically built into the boat so taking it out is not realty an option. Is there something else I can do/add to get the tank/fule system cleaned up?
Thanks for any help
Thanks for any help
