Re: Gas Tank Capacity
I don't know the fuel capacity of that boat, but... Never rely on a boat's fuel gauge to be 100% accurate. It could take burning 25% of the tank to get the sender to start reading that the level is dropping, or the gauge could read a bit over empty when the engine is running on fumes...
I topped the tank a 2 trips ago and it was still reading full after the first trip, a bit under full after the second trip, yet the tank is probably 10 gallons low (27 gallon tank)...
If you call Crestliner, they might be able to tell you what the boat's fuel tank capacity. Or, if you have access to the tank, measure it and figure out the volume, or the tank should have it's capacity marked on the top of the tank (along with other specs).
Where is the tank located, bow, stern, saddle, belly?
