nastyquedawg
Thread starter- Joined
- Dec 25, 2008
- 89
I recently bought a used boat in which the keel had worn down so much in one area that rain water would leak from the inside through the hull. Since them I have built that area up with fiberglass and sealed it marine tex. This was done in December of 2008. I took the boat out today on its maiden voyage, as me being the owner and felt like the boat is usually heavy but the NADA has the boat weight at 2100lbs, heavy for a 17ft boat. It is a center console Invader with a 90inch beam. I don't think it is common for boat manufactures to put foam in the center of the boat in the bilge but I wanted to make sure. So I remove the deck plate to determine if there was foam in the center of the boat. I saw no foam in the gas tank area but saw the gas tank resting on some type of insulation pad. The pad was very damp, is this normal?
