Gas tank vent?
emilime75
Can someone please explain the vent on a portable gas tank? Is it supposed to be open or closed when the engine is running? When are you supposed to close it?
j_martin
Re: Gas tank vent?
Close it to keep the gas in when you're bounding down the road. Open it to let air in when you're bounding across the lake.
Toxarch
Re: Gas tank vent?
If you don't open it when you are running the engine, then you create a vacuum in the tank. That will stall your engine and probably damage the fuel pump.
j_martin
Re: Gas tank vent?
Not to mention caving in your gas can, and starving the engine, leaning it out and burning it down.
PLEASE don't forget to open the vent.:D
