Re: Gas Tanks
there are pro's and con's to perm. tank vs: portable. Number 1 to consider is how often does your boat sit up before you go out again? The reason I ask is, you have to consider the condensation inside the tank, leads to water in your gas. you also have to vent the tank. As temp outside changes it will cause your tank to draw in moisture from outside air, which will turn to water in the gas, especially if its not full all the time. A water fuel seperator can take care of some of it. Although some screens will trap water at the inlet, inside of the tank. I had all these troubles at first. But in the long run It was worth the change for me. I try to keep the tanks mostly full, and go out often.<br />Randycc58
