Gasket and sealer question
Status
Not open for further replies.
ckaiser
Working on a new-to-me 98 Excel 4.3 Mercruiser alpha 1 Gen 2. One of the tasks is replacing the inside trim hoses. Dropped the connector plate at the bottom of the transom, undid all the hoses, ran the new hoses. All OK so far.
Cleaned up the connector plate. It had a lot of clear silicone gooped all over it.
Now; I have a clean plate and a new gasket. What sealer do I use? This is one of those sink-the-boat-if-I-get-it-wrong things, so I want to make sure I get it right. :)
And I'd assume that I coat both sides of the gasket?
I have some RTV Black Ultra, but I don't know that this is the correct stuff to use...
Thanks!
Charlie
tochinski
Re: Gasket and sealer question
When you said "connector plate", did you mean "Hydraulic Trim Line Connector Assembly" p/n 98825A4. It has one gasket and one rubber seal. RTV Black Ultra is similar to Quicksilver Perfect Seal and it is used on all gaskets, but not rubber seals. Yes, you use seal on both sides of gasket.
Also, you can check service manual.
http://www.4shared.com/document/IqHfWsuP/Mercruiser_Service_Manual_14_A.htm
ckaiser
Yes, that's the part I have, but there's no rubber seal. There's a large paper gasket that goes between the plate and the transom housing, and a smaller paper gasket that goes between the plate and the anode that bolts to it...
Charlie
Fun Times
Charlie
Here's your correct answers, Start on page 7A-5, Then pay close attention to pages 7A-7 & 7A-8;) then have a look at all the other pages as well.
http://www.boatfix.com/merc/Servmanl/14/14a7.pdf
ckaiser
Boattech; that's good info; I wouldn't have thought to look in that section of the manual. But one thing; it still doesn't address the gasket that sits above the trim connector plate. My new anode has the seal and gasket for below the plate, but I still can't find anything definitive on the upper gasket.
A friend who does boat repair says some permatex #3 should work, or use silicone/urethane caulk. I might call a mercruiser dealer and see what they say. Then I'll be really confused. LOL...
Thanks!
Charlie
Status
