Gasket between Carbs and Sound Attenuator?
Coloradolakeboy
1980 V-6. Should a gasket be put between the carbs and the silencer box? (aka Sound Attenenuator) The OEM gasket is obsolete. Just use carb gaskets? Any suggestions? Thanks.
Rob
hl
Re: Gasket between Carbs and Silencer Box?
Rebuilt the carbs on a 150 last spring and I just used the old gasket that was on it when I took it apart.
Coloradolakeboy
Too late to try that! Thanks away hl !
