Peter Rozenveld
Thread starter- Joined
- Jul 25, 2011
- 11
Sorry my Englisch is not so good, i'm dutch.
I have to replace the head gasket of a OMC 4 cylinder sterndrive ( i think build 1970). The gasket is made from aluminium, do i need to add some liquid gasket too on both sides of the alu gasket. My friend tells that the seller told him to do so.. I think , it's asking for problems, you don't know how thick is is at some places and then create a leak.
second question: How do i adjust the valve lash. I saw a you-tube movie that you should lossen the nuts till the push-rodds can be turned, then fasten bij a halve turn.
Is this correct?.
third question: The carburator doesn't give any fuel when the motor is running stationair, the acceleration pump is working fine, but starting the engine is big problem, and it doen't run smoothly
The fire sequence is 1,3,4,2 isn't it?
Greet, Peter
Is this correct?.
Greet, Peter
