gaskets/sealers
Cptkid570
Ensign
Is there a link anywhere that shows which gaskets need a sealer and which ones go on dry? As I put together my mercruiser 350 longblock, I know that I'll be needing to put on the:
Intake manifold
Timing chain cover
oil pan
water pump
carb
exhaust manifold
thermostat housing
any others? and I know this has been asked before, but what is the recommended gasket sealer to use?
95yj
Re: gaskets/sealers
You should get yourself a copy of the merc manual. If you're like me and have been building cars for a while, but haven't had to do too much work on your boat engines, it will give some good pointers on what is different.
The merc manual is going to tell you to use Quicksilver Perfect Seal everywhere. This is used on the timing cover, fuel pump, water circulating pump and thermostat.
Carb gasket goes on dry. Exhaust manifold gaskets go on dry. Oil pan goes on dry, but you need to put RTV sealer to the joints of the rear seal retainer and the joints of the front cover. That's a small "blob" in each of the four corners and then assemble fairly quickly as you don't want the RTV to set before assembly.
Intake manifold gaskets go on dry, but you need to put Perfect Seal around the water jacket holes and across the front and back valleys. Don't get any sealer in the oil sending hole. If your intake manifold bolt holes in the front and back go into the water jackets of the heads, you'll need to use thread sealer to keep from leaking water.
IMHO, RTV can work fine anywhere there isn't gas around as gas will eat through the RTV. Apply a light coat to one side of the gasket and let get tacky then install. Gasket shellac is for glueing gaskets on when there isn't a good surface in my opinion. If you don't overtorque, you can reuse the gaskets if you have to disassemble sometime soon. Using other sealers that harden make a mess out of cleaning gasket surfaces and ruin the gaskets when it's time to replace something.
That said, I use Perfect Seal on my boat engine anyways.
Don S
Re: gaskets/sealers
I have to disagree with the "Use Perfect seal everywhere"
First of all, it depends on what year engine Cptkid has. The newer engines with the plastic timing chain cover do not use regular gaskes. Same with the valve covers, intake manifolds etc. Imagine if he has a FORD !!!!!!
95yj
Re: gaskets/sealers
No offense Don, I know you have a lot more experience with this than I do, but when I see 350 long block, I'm pretty sure that's a SBC and not a Fix Or Repair Daily. My Merc manual says both sides of the front cover gasket get coated with Perfect Seal on the new, plastic, don't reuse them if you take them off, timing chain cover.
I didn't mention rocker arm cover gaskets. As far as I'm concerned these always go on dry with equal and minimal torqueing on all studs / bolts. Rocker arm covers leak when they get snugged up too tight.
I also should have stated that the manual says use QS Perfect Seal everywhere that gasket cement is called for even though I stated individually which applications go on dry and which get sealant.
Cptkid570
Ensign
Re: gaskets/sealers
I'm sorry for not being more specific.. it's a 1984 mercruiser 260
Don S
Re: gaskets/sealers
What kind of "MERC" manual do you have.... Note: Seloc and Clymers are NOT Merc manuals, they are aftermarket and often wrong information is given.
The "NEW" plastic timing covers don't even have a seperate gasket, let alone use sealer on both sides of it
Cptkid, what you need is the OEM Merc manual. It tells you the proper sealer for each area, along with torques and sealers used on head bolts, manifold bolts etc.
Merc manual #3 is the one you need for your engine.
95yj
Re: gaskets/sealers
DonS, I do have the Merc #17 manual.
You're right about the timing cover. It states that the following information does not apply to the Gen+ engines and the front cover is not reusable if removed. So the older timing cover like he has gets Perfect Seal around the gasket.
Sorry for the confusion and thanks for correcting me.
