schwarztot
- Joined
- Jun 16, 2009
- 3
Hi all. I have a late 80's early 90's Yamaha Pro 50. I put the motor in the water the other night and the motor ran great wide open, but it sounds a little rough at low speeds and idle. Wants to stall and bog down on the holeshot. I decided to pull the cover on the carbs and have a look. Carbs 1 and 3 look normal but carb 2 is bubbling a lot of gasoline out of the top. There is also a lot of gasoline coming out of the stem in the center of carb two but not on the other two. Gas is leaking from this carb only while the motor is running. The gas is leaking down into the engine compartment. What would be causing this? I have attached a few pics to show.
Thanks,
Travis
Thanks,
Travis
