Gauge Rigging/Tach/Hour Meter/Volt Meter 90 HP
Chesapeake Explorer
Posted here a week ago or so. rigging a new yamaha 90 on a Boston Whaler that had a 90 Evinrude. Took Rodbolts advise and bought a new Yamaha 704 top binical control, motor came with new 10 pin harness and keyswitch with horn. The 704 control takes care of the nutral switch and trim up and down switch in plug and play fashion. I could have used my old Morse control I is still good but time for a change..Now the gauges.. I may well get a new digital Yamaha gauge later on this year as I recover from this new motor cost..till then would like to at least use the Tach/ hour meter and volt meter.<br /><br />The key switch has 4 wires coming off it with plugs to plug into gauges.. Red Green Yellow Black <br />These wires have plastic plugs in them to keep water out<br /><br />The volt meter is a simple one .. two wires out to the main Boston Whaler + - bus bar.. It registers volts that it. So I will wire it up as it is..<br /><br />The Tach is a Teleflex. Now as I understand this I will attach a jumper to the red wire plug off the key switch to the ING post on the tach<br /><br />The Black plug off the key switch to the GROUND on the tach<br /><br />The green wire plug off the key switch to the SEND on the tach <br /><br />For Hour meter: Black GROUND on tach to Hr meter -<br /><br />ING on tach to + on Hr meter..(I will run a red wire ) these two terminals will have two wires each on them<br /><br />Tell me if I am wrong and whats the yellow wire for?<br /><br />Trim gauge later...I know it takes a second harness.. let me guess Pink Gray Black<br /><br />Answers will be helpfull for future OMC/to Yamaha repowering!
rodbolt
Re: Gauge Rigging/Tach/Hour Meter/Volt Meter 90 HP
no answer<br /> pay peanuts, get monkeys. dont complain
charliek1988
The yellow wire is hot when the ignition is on and the red one is hot all the time. Tach and hour meter (+) should go to yellow along with any gauge you don't want on when motor isn't running.
The trim gage can be connected with just one wire coming from the engine. It's the pink one on the four pin harness. It goes to the rheostat on the motor mount that works the gauge. The other side of the rheostat goes to ground so the ground on the gauge can be picked up under the panel where the gauges are.
