nautihabits
- Joined
- Aug 28, 2005
- 42
1992 250 Yamaha original owner. Recently, went to start and when I turned the key the gauges went blank and reset. After repeated attempts the motor finally cranked. However, while running, the gauges intermittently go blank and reset or flash different idiot lights. None of this seems to affect the running. Starting is still hit or miss. Use of the throttle trim button is also intermittent. If the gauges are not reading properly then the trim will not work but when the gauges seem to be working the trim works. I have tried bypassing the neutral cutoff and disconnected the throttle trim switch to no avail.
