CharlieZulu
- Joined
- Jun 2, 2008
- 122
Just picked up a 1987 vintage Merc 90, and ordered a manual for it. It is connected to this boat:
My boat has a speedo and tach only (and the tach doesn't actually work, although when I turn the ignition on, the needle does jump a bit, so I guess there is power there)
Anyway, I'd like to add some gauges so I know what's going on in there. Voltmeter is pretty straightforward (will wire it directly across the battery, after my switch) but here's my question:
Does this vintage Merc have the necessary sensors built in to measure water pressure, flow etc?
Also, I do not hear an alarm when I turn the ignition to ON -- same question, does this motor (90 hp 1987, serial number starts with a B) have this stuff built in, somewhere? Where is the little speaker usually located?
I did notice a couple if wires had been snipped off back there. I want to take care of this motor and I hate not knowing what's actually going on back there.
Thanks in advance.
Thanks in advance.
