Andy in NY
Thread starter- Joined
- Oct 25, 2007
- 2,109
motor is a 1974 evinrude 50 hp outboard.
i was given a gauge cluster from a mercruser sterndrive setup and would like to see if i can make any if the gauges work with my motor? the 3 in question would be volt meter, which i would assume would work with anything...
the second is a temp gauge. i know my evinrude has an overheat alarm, can i use the existing temp sensor and hook it to the gauge or will i need a new temp sensor?
third is the tach. can a tach frrom a 4 stroke 4 cyl work with a 2 stroke 2cyl?
