This is our 4th of July family week, it's being crazy around here. But it's so much nicer than on the 4th weekend, don't have to deal with the boat ramps and lake traffic.Hmm, looks like your gauge is reading 2v too high. Next step is to measure the voltage at the gauge. I'd probably check with the wiring on, and if the DVM is high I'd disconnect the leads from the voltmeter and remeasure. Lastly, I'd run a ground directly from the battery. Set the DVM to DC volts and measure between that jumper and the ground wire(s) at the helm--there shouldn't be any voltage between them. Do that KO/and engine running.
I'll get around to checking this next week, after our company leaves. Appreciate the suggestion.Check , remove bolt that holds the wire on top of the sending unit ,clean wire and bolt that holds wire on top of the sending unit . That is a common issue with fuel gauges .
And the purpose of looking for voltage between battery ground and the ground on gauge?Lastly, I'd run a ground directly from the battery. Set the DVM to DC volts and measure between that jumper and the ground wire(s) at the helm--there shouldn't be any voltage between them.
To make sure that there isn't a short to power on the ground wire causing the high readings.And the purpose of looking for voltage between battery ground and the ground on gauge?
I could see checking the resistance (ohms) but voltage between grounds?
That's weird. Key on should have 12v there..
I tested the voltage at the gauge leads connected. Key off - 0.00 volts, Key on the voltage fluctuates between 0.00 and 0.01.
That's right.Leads disconnected from volt gauge. Key off - 0 volts. Key on - 12.28 volts. Engine running, tops out at 14.16 volts.
With the volt gauge disconnected do/did the other gauges start working?This is our 4th of July family week, it's being crazy around here. But it's so much nicer than on the 4th weekend, don't have to deal with the boat ramps and lake traffic.
I think I understand the jumper part, I ran a jumper from the negative side of the battery and measured the DVM + probe from the jumper, and the DVM - probe to the ground on the volt gauge. With key on, the DVM again fluctuates between 0.00 and 0.01. Engine running, the DVM measures 0.03 eventually settling down to 0.00 after running about 45 seconds. The volt gauge at the helm still reads above 16 volts.
Also, I cleaned the wire connectors, but they really didn't need it. They all look very clean, no sign of any corrosion.
Not true. Voltmeters are designed to draw negligible current. Agree that if the voltmeter is faulty then it could be drawing some current and affecting the rest of the circuit. Key on zero volts across it would mean a dead short though. And OP had the voltmeter reading 14+ previously.With the volt gauge disconnected do/did the other gauges start working?
If so, the volt gauge is shorted (faulty) and is overloading the instrument cluster wiring.
If not, there is likely a marginal connection in the power/ground feeding the instrument cluster. Analog gauges (especially voltmeters) draw an appreciable amount of current but digital volt meters do not. As a result, without a load, it's possible to see full voltage through a high-resistance connection (as voltage drop is a factor of resistance and current, more current means more drop).
Not buying it….Picks up issues particularly under load that a resistance test will miss (small static resistance that becomes significant with high current passing through).
Valid point... if the voltage is coming back to normal with just the volt gauge disconnected (other gauges still connected) and swinging from 0 to full system voltage, then that points to the fault being an internally shorted volt gauge or some other short that was corrected by disconnecting said gauge.Not true. Voltmeters are designed to draw negligible current. Agree that if the voltmeter is faulty then it could be drawing some current and affecting the rest of the circuit. Key on zero volts across it would mean a dead short though. And OP had the voltmeter reading 14+ previously.
That a voltage drop test isn't a thing?Not buying it….
I'm not sure what happened there in my original comment about the voltage, so I redid the test with the Key on, and it is reading 12v. I must have messed that one up, sorry about that, it's not right for me to be asking for help and I'm giving bad info.That's weird. Key on should have 12v there.I tested the voltage at the gauge leads connected. Key off - 0.00 volts, Key on the voltage fluctuates between 0.00 and 0.01.
The other gauges (fuel and tach) did not start working normally. Of course I had to start the engine to check the tach, but it's been just flat out wonky since last year, and it's still wonky with this test. With the tach, I've tried moving the cylinder selector switch on the back several times last year, it didn't help.With the volt gauge disconnected do/did the other gauges start working?
Being wonky, the tach would pause, then jump to an RPM that was near accurate, it would do this randomly, and slowly increased in frequency till now it's mostly just dead, rarely moving, right now it thinks it's running about 4,000 RPM's, key off/key on/engine running. The hour meter hasn't increased lately. I'll clean the coil connections along with the fuel sending unit connections, which @mr 88 suggested doing. If none of that helps, I'll disconnect the gray wire altogether and run a jumper directly to the tach to see if it dewonkifies it.Alright, sounds like you officially have a bad volt gauge. Fuel gauge sounds OK, wouldn't worry about where it settles key off.
Last is the tach. "Wonky" might need a better description. First step is cleaning the connection at the coil (you said already clean at the helm) or disconnect the gray wire altogether and run a jumper directly to the tach to see if it dewonkifies it.
Another super helpful comment. Keep them coming.Keep running everything. Long after a simple problem appears.
I cleaned the fuel sending connections, they needed cleaning but it didn't make a difference. I agree about the fuel gauge, it's not worth any more effort.Alright, sounds like you officially have a bad volt gauge. Fuel gauge sounds OK, wouldn't worry about where it settles key off.
