Gauges
mikerdta
Will these gauges work on a mercury 2015 115 hp 4 stroke. If so where coukd i find a diagriam on what wire goes to what pin .part number for the multi fuction guages are mpg/fuel 947974 rpm/volt 947975
Silvertip
Voltmeter and fuel gauge are not engine dependent so they will work. Voltmeter just needs a positive and negative 12V connection as well as an internal light connection to the light switch. Same for fuel gauge but the "S" terminal on the gauge connects to the sender in the fuel tank. Tach connects to engine ignition system but you will need to check diagrams to see how/where. Trim is engine dependent and the sender is on the drive. If this gauge set is a replacement for existing gauges, disconnect the old, connect the new and test it. Get one gauge working before you dynamite the entire cluster. That way you know what you screwed up or did correctly in the process.
