Gear case head
TIDECRAFT
I have A 68 modle evinrude 65 hp The GEAR CASE HEAD is on tite how is the best way to re move after the bolt s are out .? :eek: :confused:
TORX
Re: Gear case head
IF IT IS THE EXAUST HOUSING or prop shaft housing you can uses a wheel puller there are two treded holes in the housing bolt the puller to them and against the prop shaft titen the puller and it will pull the housing out
OBJ
Re: Gear case head
Hi Tidecraft....<br /><br />Torx has the right idea. If'n memory serves, the holes are 1/4" NC threads. Get a piece of all-thread and cut lengths to suit. Should work with most all pullers.<br /><br />Jim
TIDECRAFT
Re: Gear case head
Ok I got a wheel puller and had to make a bolt long enough to fit the puller and it worked like a charm Thanks for the help.
