mark89coupe
Thread starter- Joined
- Dec 8, 2007
- 13
I have a 1993 Stingray with a Mercruiser 4.3/Alpha One Gen 2.
I recently changed the water pump/impeller in the lower drive. After I put it all together the outdrive oil started to leak out where the muffs go on.
I did use all gaskets and rings that came with the impeller kit. I did double check diagrams online and I did put it all back together correctly.
It did not leak prior to this BUT when I originally drained the outdrive oil, gear oil came out (the smelly stuff from auto rear ends). The oil I put back in is blue and dont smell as bad.
Where do I start.
Where do I start.
