erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
As mentioned in another thread, I managed to crunch a magnet, the tip from the lower gear case lube screw, in my drive. I think it blocked the shift assembly, so when I move the shaft it snapped the tip off.
I recovered some of it, but the rest seems in small pieces or otherwise unrecoverable.
I obviously have the option of paying a shop a few hundred $$ to open the lower unit up and clean it out.
So what I'm wondering is, how bad is it to have the shards in there? We're talking grit the size of coarse sand down to almost microscopic.
It's not metal, it's ceramic... I looked up the material, and it's typically a Rockwell C scale hardness of 59... which unfortunately is nearly has hard as most case hardened gears. Anyone know how hard mercruiser gears are?
I suspect what will happen is that if the magnet bits circulate (they may not, they're mostly stuck on the shift mechanism) and end up in the forward or reverse gears or on the bearing contact surfaces they'll get crushed into small bits... the ceramic is very brittle.
So I could end up with scratches and faster than normal wear in that area. It doesn't help that they're magnetic, so they will tend to stay where they touch steel. I suppose the gears would tend to sling lube toward the outer case, so they might clean their faces themselves.
Anyone have any thoughts on this? If you spilled a pencil eraser size amount of sand into the gear case, how long before it failed?
I'm kinda upset about this... I saved some cash by buying a used gear case, and now it looks like I may need a new one anyway....
Erik
PS: I did think of one more thing... putting a stronger magnet inside the gear case to try to attract more shards... I'll try that in a bit. and I'll be careful not to break it.
Erik
