krisnowicki
- Joined
- Jul 11, 2007
- 1,172
Changed my gear lube on my bravo one drive. I removed the bottom drain and top plug... drained it out. put the pump in the bottom filled it up. When it was full put the top plug in then the bottom. Then Refilled the bottle in the boat. Maybe filled it up to much
when I was out running the lube drained down a about 1/6 of the gear lube monitor bottle, and it has a little.... a very little, I mean like enough to occupy the corner of the bottle of emulified oil. Like less than a 1/4 of an ounce.
Is this water oil mix just condensation or something? Can you over filll the bottle and what happens when you do?
