Gear lube pump
kbh121956
Just wondering where people find the 1 quart gear lube pump with the adapter that fits the small force drain screw on the bottom. I believe that it's a 1/8 or 1/4 allen screw? Thank you.
kbh121956
With the proper size of adapter? I've bought a couple and the aluminum adapter is wrong.
jerryjerry05
Always include the year, HP and model(if known)
You don't fill from the bottom.
If it has an allen headed set screw then you don't fill from there.
Top stbd. side is the fill vent screws.
Fill from one and then fill from the other when it comes out.
Horse4190
If it is a 85 HP Force, the instruction manual says to fill in the gear oil from the drain screw (allen). I might be wrong but that is in the manual. Be careful NOT to open the Shift Pivot Screw like mine that I pulled it wrongly.
jerryjerry05
Horse, you are wrong:)
What manual are you reading??
Clymer/ Seloc?
Another reason NOT to buy them.
I've NEVER seen an adaptor that fits the allen head set screw.
The older Chryslers had a drain plug where you filled the lower but not the bigger Forces.
kbh121956
Thanks guy's Jerry is correct. I've always filled from the bottom until oil came from the vent screw. The larger Force engines do have a vent and fill screw just below the cavitation plate. Almost at the same level also... Strange.
jerryjerry05
They used the vent/fill because the hole for the allen screw is so small.
Just make sure when filling to fill until it comes from the vent and then fill the other way until it comes from the fill.
That makes sure it's got enough oil(maybe a bit too much??).
