FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
looks or sounds like water in the lu.drain and change fluid .then put new drain,fill washers on try it for say half to an hour drain again if its still that chocalate swirl youll need to put in new seals.good luck.<br /> ***1971 18' winner 1969 115 jonny*** <br /> "thursday"
Your gearcase is a hydro-electric, not selectric. That is a very good gearcase, but you must keep the water out of it.If it has a water leak, you must find, and fix it.If it were mine, I would replace the drive, and prop shaft seals, along with the prop shaft bearing carrier oring. and retaining bolt o-rings. This really is not a hard job with the proper manual.
Thanks. Ill change the seals and orings. I just got this boat this year and have no idea how long its been since the lube has been changed. Thanks again guys.
